LTM4601 DC/DC微型模块性能
消耗积分:0 | 格式:pdf | 大小:164 KB | 2012-01-05
分享资料个
The LTM4601 DC/DC μModule regulator is a completehigh power density stepdown regulator for up to 12Acontinuous (14A peak) loads. The device is housed ina small 15mm ¥ 15mm ¥ 2.8mm LGA surface mountpackage, thus the large power dissipation is a challengein some applications. This thermal application note willprovide guidelines for using the μModule regulator inambient environments with or without air fl ow. Loadcurrent derating curves are provided for several inputvoltages and output voltages versus ambient temperatureand air fl ow.
评论(0)
发评论
下载排行榜
