MAX2079完全集成的八通道超声接收器(八路LNA、VGA、AAF、ADC和CWD波束成形)
新品快讯
29人已加入
美信电子推出MAX2079完全集成的八通道超声接收器(八路LNA、VGA、AAF、ADC和CWD波束成形)
MAX2079概述
The MAX2079 fully integrated octal ultrasound receiver is optimized for high channel count, high-performance portable and cart-based ultrasound systems. The easy-to-use integrated receiver allows the user to achieve high-end 2D and Doppler imaging capability using substantially less space and power. The highly compact low-noise amplifier (LNA), variable-gain amplifier (VGA), anti-alias filter (AAF), analog-to-digital converter (ADC), and digital highpass filter (HPF) achieve an ultra-low 2.8dB noise figure at RS = RIN = 200Ω with a very low 120mW per channel power dissipation at 50Msps. The full receive channel has been optimized for second-harmonic imaging with an exceptional 76dBFS SNR over a 2MHz bandwidth, and -70dBc second-harmonic distortion at fRF = 5MHz over the full receiver gain range. Near-carrier dynamic range has also been optimized for exceptional pulsed and color-flow Doppler performance under high-clutter conditions. The bipolar front-end and CMOS ADC achieve an exceptional near-carrier SNR of 137dBFS/Hz at 1kHz from a 5MHz tone for excellent low-velocity Doppler sensitivity.
The device also includes an octal CWD beamformer for a full Doppler solution. Separate mixers for each channel are available for optimal CWD sensitivity.
The MAX2079 octal ultrasound front-end is available in a small, 10mm × 10mm, CTBGA package and is specified over the 0°C to +70°C temperature range.    数据资料
MAX2079关键特性
Minimizes PCB Area and Design Cost
8 Full Channels of LNA, VGA, AAF, 12-Bit ADC, Digital HPF and CWD Mixer Beamformer in a Small, 10mm × 10mm CTBGA Package Improves System Sensitivity  Ultra-Low Full-Channel Noise Figure of 2.8dB at RS = RIN = 200Ω
Improves System Dynamic Range
76dBFS Image Path SNR Over 2MHz Bandwidth at fRF = 5MHz
137dBFS/Hz Image Path SNR at 1kHz Offset from fRF = 5MHz
Consumes Less Power
Ultra-Low Power of Only 120mW per Full Channel in Imaging Mode at 50Msps
Selectable Active Input Impedance Matching of 50Ω, 100Ω, 200Ω, and 1kΩ
Programmable VGA Output Clamp
Integrated Selectable 3-Pole 9MHz, 10MHz, 15MHz, and 18MHz Butterworth Anti-Alias Filter Programmable, Digital Highpass, 2-Pole Filter
Serial LVDS Digital Outputs
Fast Recovery Low-Power Modes (< 2µs)
Separate Channel I/Q CWD Mixers for Improved Dynamic Range and Sensitivity
