LM49153 G类耳机放大器解决方案
模拟技术
2314人已加入
  NS 公司的LM49153是全集成音频子系统,包括高效25mW的G类耳机放大器(THD+N ≤ 1%)和高效的1.35W D类扬声器放大器(RL = 8Ω, THD+N < 1%),通过I2C进行音量,模式选择和关断控制,主要用在手机和智能手机。本文介绍了LM49153主要指标,主要特性,典型音频放大器应用电路以及演示板电路图和材料清单,元件布局图。
  The LM49153 is a fully integrated audio subsystem designed for portable handheld applications such as cellular phones.
  Part of National’s PowerWise family of products, the LM49153 combines an earpiece switch, a high efficiency 25mW class G headphone amplifier, and a high efficiency 1.35W class D loudspeaker into a single device.
  The headphone amplifiers feature National’s class G ground referenced architecture that creates a ground-referenced output with dynamic supply rails for optimum efficiency. The
  class D amplifier features an ALC (Automatic Level Control) with a noise gate that provides both no-clip and speaker protection.
  Mode selection, shutdown control, and volume are controlled through an I2C compatible interface. Click and pop suppression eliminates audible transients on power-up/down and during shutdown. The LM49153 is available in an ultra-small 25-bump 0.4mm pitch micro SMD package (2.30mm x 2.42mm).
  LM49153主要指标:
  ■ Class G Headphone Amplifier,
  HPVDD = 1.8V, RL = 32Ω
  IDDQHP 1.2mA (typ)
  POUT, THD+N ≤ 1% 25mW (typ)
  HP VOS 0.5mV (typ)
  ■ Mono Class D Speaker Amplifier
  RL = 8Ω, THD+N < 1%
  POUT, LSVDD = 5.0V 1.35W (typ)
  POUT, LSVDD = 3.6V 680mW (typ)
  Efficiency 88% (typ)
  LM49153主要特性:
  ■ Class G Ground Referenced Headphone Outputs
  ■ High Efficiency Class D Amplifier with Spread Spectrum
  ■ No Clip
  ■ Speaker Protection
  ■ Noise Gate
  ■ I2C Volume and Mode Control
  ■ Advanced Click-and-Pop Suppression
  ■ Micro-power shutdown
  LM49153应用:
  ■ Feature phones
  ■ Smart phones
耳机放大器
  图1。LM49153典型音频放大器应用电路
耳机放大器
  图2。LM49153演示板电路图
  LM49153演示板材料清单:
耳机放大器
耳机放大器
  图3 LM49153演示板元件布局图(顶层)
