汽车遥控天线调节器和电流检测放大器的外部元件的选择
消耗积分:0 | 格式:pdf | 大小:131 KB | 2012-02-06
分享资料个
Abstract: This application note helps system designers choose the correct external components for use with the MAX16946 remoteantenna regulator and current-sense amplifier (CSA), ensuring that automobile antenna-detection subsystems meet their performanceobjectives. An electronic calculator is provided that helps specify the critical external components for the MAX16946. The calculatoralso determines the device's operational ranges and analog output voltage accuracy.
评论(0)
发评论
下载排行榜
