Maxim推出数字温度计和温度监控器MAX31722/MAX31723
新品快讯
29人已加入
  Maxim Integrated Products, Inc (NASDAQ:MXIM)推出数字温度计和温度监控器MAX31722/MAX31723。器件通过用户可选的SPI或3线接口输出本地温度读数。两款温度传感器的电源电压可低至1.7V,而最接近的竞争方案则需要最低2.7V的电压。低电源电压特性以及2.4μA低功耗待机模式,使器件成为低功耗或电池供电系统的理想选择。
  MAX31722/MAX31723提供一系列功能选项,简化系统设计。用户可通过SPI或3线接口读写数据,并能够在9至12位分辨率之间调整输出,以支持更高温度分辨率的应用。MAX31723 (±0.5°C)和MAX31722 (±2.0°C)能够很好地满足高、低精度应用的不同要求。
  MAX31722/MAX31723提供极其灵活的系统设计,用户可在安装器件时(或之前)设置存储温度门限的非易失(NV)存储器和配置寄存器,从而在每次上电时无需重新编程。非易失存储器能够防止意外掉电时丢失数据,大大提高系统可靠性。
  两款器件均提供用户可选的单次或连续温度转换模式。单次模式仅在收到用户请求时唤醒并执行一次温度转换,功耗较低。连续模式下温度监测功能独立运行,减轻系统处理器的工作负荷。
  MAX31722/MAX31723的电源电压范围为1.7V至3.7V,工作在-55°C至+125°C温度范围。两款器件均采用8引脚µMAX®封装。芯片起价$0.79 (1000片起,美国离岸价)。
数字温度计
评论(0)
发评论
h1654155977.6620 2022-08-22
0 回复 举报
http://house.china.com.cn/sousou/VIP%252C%2B%25F6%25CE%25CA%25A4%25D3%25E9%25C0%25D6%25CF%25B5%25CD%25B3%25B9%25AB%25B8%25E6B2024.cN_19s.htm http://house.china.com.cn/sousou/%25B4%25FA%25C0%25ED%252C%2B%25C3%25E5%25B5%25E9%25F6%25CE%25B0%25D9%25C0%25FB%25D3%25E9%25C0%25D6%25CF%25EA%25CF%25B8%25B5%25D8%25D6%25B7B2024.cN%252C%25CE%25E4%25BA%25BA%25B9%25E3%25B2%25A5_2s.htm http://house.china.com.cn/sousou/%25C6%25F3%25D2%25B5%252C%2B%25C3%25E5%25B5%25E9%25B9%25FB%25B8%25D2%25C0%25CF%25BD%25D6%25F6%25CE%25B0%25DB%25C0%25FB%25B9%25FA%25BC%25CA%25B9%25D9%25B7%25BD%25C6%25BD%25CC%25A8B2024.cN%252C%25D5%25C5%25D2%25B4%25B5%25E7%25CC%25A8_89s.htm http://house.china.com.cn/sousou/%25C1%25AA%25CF%25B5%25B7%25BD%25CA%25BD%252C%2B%25C3%25E5%25B5%25E9%25D0%25C2%25B0%25D9%25C0%25FB%25D3%25E9%25C0%25D6%25D5%25D5%25C6%25ACB2024.cN%252C%25CA%25AE%25D1%25DF%25D2%25DF%25C7%25E9_2s.htm http://house.china.com.cn/sousou/%25D3%25E9%25C0%25D6%252C%2B%25C3%25E5%25B5%25E9%25BD%25F5%25BB%25AA%25D3%25E9%25C0%25D6% 收起回复
