WISMO Quik Q3100 series
消耗积分:0 | 格式:rar | 大小:555 | 2009-05-15
分享资料个
WISMO Quik Q3106
Customer Design Guidelines
WISMO Quik Q3106 module is a self-contained E-GSM/GPRS 900/1800 dual
band module designed to meet various types of applications. The module is
available in several memory sizes (FLASH and RAM) and includes the following
main features:
• 32 x 44 x 3 mm,
• 2 Watts E-GSM 900 radio section running under 3.6 Volts,
• 1 Watt DCS 1800 radio section running under 3.6 Volts,
• Digital section running under 2.8 Volts,
• 1.8 V / 3 V SIM card interface,
• Real Time Clock with calendar,
• Battery charge management,
• Echo Cancellation + noise reduction,
• Full GSM or GSM/GPRS software stack,
• Hardware GPRS class 10 capable,
• Complete shielding,
• Complete interfacing through a 100-pin connector:
o Power supply,
o Serial links (UART1, UART2, SPI1, SPI2 and 2-wire bus),
o Audio (main audio interface + auxiliary audio interface),
o Keyboard,
o SIM card,
o Buzzer and vibrator,
o A 16-bit parallel bus allowing various device selection (an example
of application is given in paragraph 2.2.3).
• Several GPIOs are available to drive customer I/O applications:
o Up to 8 Inputs/Outputs,
o Up to 3 Outputs,
o Up to 1 Input.
Note: due to signal multiplexing, the number of available I/O depends on
the functions used on the module.
WISMO Quik Q3106 module has just one external connection: General Purpose
Connector (GPC) to Digital, Keyboard, Audio, Supply, and 50 Ω adapted RF connection.
评论(0)
发评论
下载排行榜
