瑞萨电容触摸技术之低功耗应用—RX140实验环节(5)-3
Lab Session 4
在Lab 3的基础上增加低功耗 (Auto Judgement) 功能
5.4
增加低功耗 (Auto Judgement) 功能应用程序
5.4.1 将培训配套资料Checkpoints文件夹中的工程 "Lab session 4" 中的qe_gen文件的 "qe_touch_sample.c" 拷贝
并覆盖 "Project Explorer" 的Lab_session_1工程中qe_gen文件的 "qe_touch_sample.c".
5.4.2 应用程序代码说明
使用init_peripheral_function初始化需要使用的外设
使用R_CTSU_Open() 初始化config01 (MEC电极)
使用RM_TOUCH_Open() 初始化config02 (12个自容式按键)
/* Initialize peripheral functions */
init_peripheral_function();
/* Open Touch middleware */
err = R_CTSU_Open (g_qe_ctsu_instance_config01.p_ctrl, g_qe_ctsu_instance_config01.p_cfg);
ctsu_ctrl = (ctsu_instance_ctrl_t *)g_qe_ctsu_instance_config01.p_ctrl;
err = RM_TOUCH_Open (g_qe_touch_instance_config02.p_ctrl, g_qe_touch_instance_config02.p_cfg);
5.4.3 应用程序代码说明
以下代码完成config01 (MEC电极) 和 config02 (12个自容式按键电极) 的初始化偏置电流调整。
/* Initial Offset Tuning */
    (void)R_LPT_SetCMT(LPT_CH1, (uint32_t)WAKEUP_LPT_PERIOD_NORMAL);
    /* Method1 offset tuning */
    do
        err = R_CTSU_ScanStart (g_qe_ctsu_instance_config01.p_ctrl);
        if (FSP_SUCCESS != err)
            while (true) {}
        (void)R_LPT_Control(LPT_CMD_START);
        while (0 == g_qe_touch_flag) {}
        g_qe_touch_flag = 0;
        err = R_CTSU_OffsetTuning (g_qe_ctsu_instance_config01.p_ctrl);
    } while(err != FSP_SUCCESS);
    /* Method2 offset tuning */
    do
        err = RM_TOUCH_ScanStart (g_qe_touch_instance_config02.p_ctrl);
           while (true) {}
       err = RM_TOUCH_DataGet(g_qe_touch_instance_config02.p_ctrl, &button_status02, NULL, NULL);
5.4.4 应用程序代码说明
以下代码完成config01 (MEC电极) 在Normal模式下的baseline调整。
/* base line setting @method1 */
for (uint32_t i = 0U; i < WAKEUP_TIME_BASELINE; i++)
         while (true) {}
     R_BSP_SoftwareDelay(WAKEUP_WAIT_MEASUREEND, BSP_DELAY_MILLISECS);
     (void)R_LPT_Control(LPT_CMD_STOP);
     (void)R_LPT_Control(LPT_CMD_COUNT_RESET);
     ctsu_ctrl->state = CTSU_STATE_SCANNED;
     err = R_CTSU_AutoJudgementDataGet (g_qe_ctsu_instance_config01.p_ctrl,   &button_status01);
     if (FSP_SUCCESS == err)
        RM_TOUCH_MonitorAddressGet (g_qe_touch_instance_config02.p_ctrl,
                                    &monitor_buf_address,
                                    &monitor_id_address,
                                    &monitor_size_address);
       qe_monitor_autojudge (g_qe_ctsu_instance_config01.p_ctrl);
5.4.5 应用程序代码说明
以下代码完成进入低功耗模式的操作,在低功耗模式里完成config01 (MEC电极) 的测量和自动判断,当config01 (MEC电极) 有按键On判断是时,退出低功耗,并通过R_CTSU_AutoJudgementDataGet() 取得结果。
/* Standby mode */
    /* for [CONFIG01] configuration */
    (void)R_LPT_SetCMT(LPT_CH1, (uint32_t)WAKEUP_LPT_PERIOD_STANDBY);
    /* Enter software standby mode */
    lpc_err = R_LPC_LowPowerModeActivate(&activate_standby_callback);
    if (LPC_SUCCESS != lpc_err)
        while (true) {}
5.4.6 应用程序代码说明
以下代码为进入Software Standby Mode时的Callback程序,用于启动Low-power Timer定时器。
/* activate_standby_callback */
static void activate_standby_callback(void *p_data)
    lpt_err_t  lpt_err;
    /* Start LPT count */
    lpt_err = R_LPT_Control(LPT_CMD_START);
    if (LPT_SUCCESS != lpt_err) while(1);
5.4.7 应用程序代码说明
以下代码为退出Snooze Mode时的Callback程序,用于停止和复位Low-power Timer定时器,以及disable snooze release interrupt。
/*snooze_callback*/
static void snooze_callback(void *p_data)
    lpt_err_t lpt_err;
    lpc_err_t lpc_err;
    /* Stop LPT count */
    lpt_err = R_LPT_Control(LPT_CMD_STOP);
    /* Reset LPT count */
    lpt_err = R_LPT_Control(LPT_CMD_COUNT_RESET);
    /* Disable snooze release interrupt */
    lpc_err = R_LPC_SnoozeModeConfigure(&gs_snooze_mode);
    if (LPC_SUCCESS != lpc_err) while(1);
5.4.8 点击电容触摸图标,编译程序。
5.4.9 以上应用程序代码的详细解释
您可参考瑞萨官网的应用笔记RX140 Group Smart Wakeup Solution Rev.1.00以及配套的样例程序
电容触摸
审核编辑:刘清
