使用H桥变压器驱动器,充电超级电容器
消耗积分:0 | 格式:pdf | 大小:73 KB | 2012-04-09
分享资料个
Abstract: With its small size and large load (10W) capability, the MAX13256 H-bridge transformer driver is an attractive solution forcharging supercapacitors (supercaps). However, a large capacitance on the output of the circuit can force the driver into fault modeat startup, due to the high initial charge current. This application note presents a solution that allows users to charge a largecapacitance without going into fault.
评论(0)
发评论
下载排行榜
