智能照明控制器测量环境光线
消耗积分:0 | 格式:pdf | 大小:359 KB | 2012-04-24
分享资料个
Abstract: This application note explains how to design an intelligent lighting controller that senses and measures the ambient lightlevel with an ambient light sensor (ALS). Equipped with a real-time clock (RTC), the controller also knows when to turn lighting on oroff at specified times. The system presented in this document can be used to control all luminaires that are mains-supply operated.Controller software is also provided in hex format.
评论(0)
发评论
下载排行榜
