MAX9928F,MAX9929F UCSP电流检测放大器
消耗积分:0 | 格式:pdf | 大小:233 KB | 2012-05-09
分享资料个
The MAX9928/MAX9929 low-cost, uni-/bidirectional,high-side, current-sense amplifiers are ideal for monitoringbattery charge and discharge currents in notebooks,cell phones, and other portable equipment.These devices feature a wide -0.1V to +28V input common-mode voltage range, low 20μA supply current withVOS less than 0.4mV, and a gain accuracy better than1.0%. The input common-mode range is independentof the supply voltage, ensuring that the current-senseinformation remains accurate even when the measurementrail is shorted to ground.
评论(0)
发评论
下载排行榜
