三人表决器:VHDL源代码
HDL语言及源代码
6人已加入
  --三人表决器(三种不同的描述方式) vhdl
  -- Three-input Majority Voter
  -- The entity declaration is followed by three alternative architectures which achieve the same functionality in different ways.
  ENTITY maj IS
  PORT(a,b,c : IN BIT; m : OUT BIT);
  END maj;
  --Dataflow style architecture
  ARCHITECTURE concurrent OF maj IS
  BEGIN
  --selected signal assignment statement (concurrent)
  WITH a&b&c SELECT
  m <= '1' WHEN "110"|"101"|"011"|"111",'0' WHEN OTHERS;
  END concurrent;
  --Structural style architecture
  ARCHITECTURE structure OF maj IS
  --declare components used in architecture
  COMPONENT and2 PORT(in1, in2 : IN BIT; out1 : OUT BIT);
  END COMPONENT;
  COMPONENT or3 PORT(in1, in2, in3 : IN BIT; out1 : OUT BIT);
  END COMPONENT;
  --declare local signals
  SIGNAL w1, w2, w3 : BIT;
  BEGIN
  --component instantiation statements.
  --ports of component are mapped to signals
  --within architecture by position.
  gate1 : and2 PORT MAP (a, b, w1);
  gate2 : and2 PORT MAP (b, c, w2);
  gate3 : and2 PORT MAP (a, c, w3);
  gate4 : or3 PORT MAP (w1, w2, w3, m);
  END structure;
  --Behavioural style architecture using a look-up table
  ARCHITECTURE using_table OF maj IS
  BEGIN
  PROCESS(a,b,c)
  CONSTANT lookuptable : BIT_VECTOR(0 TO 7) := "00010111";
  VARIABLE index : NATURAL;
  BEGIN
  index := 0; --index must be cleared each time process executes
  IF a = '1' THEN index := index 1; END IF;
  IF b = '1' THEN index := index 2; END IF;
  IF c = '1' THEN index := index 4; END IF;
  m <= lookuptable(index);
  END PROCESS;
  END using_table;
