鸿蒙OpenHarmony【标准系统 编写“Hello World”程序】(基于RK3568开发板)
1.2w人已加入
编写“Hello World”程序
下方将展示如何在单板上运行第一个应用程序,其中包括新建应用程序、编译、烧写、运行等步骤,最终输出“Hello World!”。
示例目录
示例完整目录如下:
applications/sample/hello
│── BUILD.gn
└── src
    └── helloworld.c
`HarmonyOS与OpenHarmony鸿蒙文档籽料:mau123789是v直接拿`
开发板
开发步骤
请在源码目录中通过以下步骤创建“Hello World”应用程序。
  1. 新建目录及源码。
    新建applications/sample/hello/src/helloworld.c目录及文件,代码如下所示,用户可以自定义修改打印内容(例如:修改OHOS为World)。当前应用程序可支持标准C及C++的代码开发。
    #include < stdio.h >
    int main(int argc, char **argv)
        printf("nn");
        printf("nttHello OHOS!n");
        printf("nnn");
        return 0;
  2. 新建编译组织文件。
    新建applications/sample/hello/BUILD.gn文件,内容如下所示:
    import("//build/lite/config/component/lite_component.gni")
    lite_component("hello-OHOS") {
      features = [ ":helloworld" ]
    executable("helloworld") {
      output_name = "helloworld"
      sources = [ "src/helloworld.c" ]
  3. 添加新组件。
    修改文件build/lite/components/communication.json,添加组件hello_world_app的配置,如下所示为communication.json文件片段,"##start##"和"##end##"之间为新增配置("##start##"和"##end##"仅用来标识位置,添加完配置后删除这两行):
      "components": [
          "component": "camera_sample_communication",
          "description": "Communication related samples.",
          "optional": "true",
          "dirs": [
            "applications/sample/camera/communication"
          "targets": [
            "//applications/sample/camera/communication:sample"
          "rom": "",
          "ram": "",
          "output": [],
          "adapted_kernel": [ "liteos_a" ],
          "features": [],
          "deps": {
            "components": [],
            "third_party": []
    ##start##
          "component": "hello_world_app",
          "description": "hello world samples.",
          "optional": "true",
          "dirs": [
            "applications/sample/hello"
          "targets": [
            "//applications/sample/hello:hello-OHOS"
          "rom": "",
          "ram": "",
          "output": [],
          "features": [],
          "deps": {
            "components": [],
            "third_party": []
    ##end##
          "component": "camera_sample_app",
          "description": "Camera related samples.",
          "optional": "true",
          "dirs": [
            "applications/sample/camera/launcher",
            "applications/sample/camera/cameraApp",
            "applications/sample/camera/setting",
            "applications/sample/camera/gallery",
            "applications/sample/camera/media"
鸿蒙开发指导文档:[qr23.cn/FBD4cY]
  1. 修改单板配置文件。
    修改文件vendor/hisilicon/hispark_taurus/config.json,新增hello_world_app组件的条目,如下所示代码片段为applications子系统配置,"##start##"和"##end##"之间为新增条目("##start##"和"##end##"仅用来标识位置,添加完配置后删除这两行):
            "subsystem": "applications",
            "components": [
              { "component": "camera_sample_app", "features":[] },
              { "component": "camera_sample_ai", "features":[] },
    ##start##
              { "component": "hello_world_app", "features":[] },
    ##end##
              { "component": "camera_screensaver_app", "features":[] }
