安富利DVII/OFMC模块数字视频接口解决方案
接口/总线/驱动
50人已加入
  Avnet公司的DVI I/O FMC模块提供数字视频接口,直接连接到Xilinx® Spartan®-6或 Virtex®-6 FMC使能的基板,数字DVI视频源为模块提供视频内容,而模块提供数字DVI和DisplayPort输出,用来显示FPGA驱动的视频内容。本文介绍了DVI I/O FMC模块主要特性,框图,DVI输入和输出框图,DisplayPort输出框图,以及模块电路图和材料清单(BOM)。
  This FMC module provides a direct interface to digital video to Xilinx® Spartan®-6 or Virtex®-6 FMC-enabled baseboards. A digital DVI video source can provide video content to the module. The module also provides digital DVI and DisplayPort outputs to display FPGA driven video content.
  The DVI I/O FMC Module is not a stand-alone module, but rather a plug-in module designed to interface with FMC compatible baseboards. In that role, the DVI I/O FMC Module provides a number of video interfaces to its host via a LPC FMC connector.
  The DVI I/O FMC Module is a low pin count (LPC) FMC module containing interfaces intended for video processing. This module contains no processing intelligence and requires that it be plugged into a compatible baseboard for power, control and data processing.
  DVI I/O FMC模块主要特性:
  Video Input
  — DVI input interface (HDMI connector)
  Video Output
  — DVI output interface (HDMI connector)
  — DisplayPort output interface
  Clock Source
  — Video clock synthesizer
  I2C Configuration
  — IPMI Identification EEPROM
  — Peripheral configuration
  Other I/O
  — General-purpose I/O pins
  图1.DVI I/O FMC模块外形图
  图2.DVI I/O FMC模块框图
  安富利
  图3.DVI I/O FMC模块DVI输入框图
  安富利
  图4.DVI I/O FMC模块DVI输出框图
  安富利
  图5.DVI I/O FMC模块DisplayPort输出框图
  安富利
  图6.DVI I/O FMC模块电路图(1)
  安富利
  图7.DVI I/O FMC模块电路图(2)
  安富利
  图8.DVI I/O FMC模块电路图(3)
  安富利
  图9.DVI I/O FMC模块电路图(4)
  安富利
  图10.DVI I/O FMC模块电路图(5)
  安富利
  图11.DVI I/O FMC模块电路图(6)
  DVI I/O FMC模块材料清单(BOM):
  安富利
  安富利
  详情请见:
  https://www.em.avnet.com/Support%20And%20Downloads/AES-FMC-DVI-G-01_HG.pdf
  https://www.em.avnet.com/Support%20And%20Downloads/AES-FMC-DVI-G-01-SCH_041310.pdf
