单声道D类放大器在电路中的应用
消耗积分:0 | 格式:rar | 大小:111 | 2009-06-04
分享资料个
The TDA7480/81/82 are single ended , split supply, class_D amplifiers. The output of the amplifier is a high frequency square wave (around 100Khz), rail to rail, with variable duty cycle.
The audio information is the average value of the output square wave.
To obtain the audio signal, the output must be low pass filtered.
The main issue of this amplifier is the very low dissipated power (the very high efficiency) compared to a normal class AB amplifier.
评论(0)
发评论
下载排行榜
