MAX31180,pdf datasheet
消耗积分:0 | 格式:pdf | 大小:384 KB | 2013-01-07
分享资料个
The MAX31180 is a low-jitter, crystal-based clock generatorwith an integrated phase-locked loop (PLL) togenerate spread-spectrum clock outputs from 16MHz to134MHz. The device is pin-programmable to select theclock multiplier rate as well as the dither magnitude. TheMAX31180 has a spread-spectrum disable mode and apower-down mode to conserve power.
评论(0)
发评论
下载排行榜
