xapp134 verilog源代码
消耗积分:0 | 格式:rar | 大小:33 | 2009-06-14
分享资料个
xapp134 verilog代码
The SDRAM controller is designed for the Virtex V300bg432-6. It's simulated with Micron SDRAM models.  The design is verified with backannotated simulation at 125MHz
1. Is RAS to CAS delay programmable?
  . No, the data registers has a fixed number of pipeline stages.  This reference design supports RAS-to-CAS delay of 2 clock cycles.  If you need to adjust to a different RAS-to-CAS delay, change the SRL16 Address values in sys_int.v.  The address value should be (Trcd/Tck) +1
  . Note, you still need to write the RAS-to-CAS value to the Controller's Mode Reg during PRECHARGE command.  The value should be (Trcd/Tck) -2
2. How do I modify the design to support 128Mb/256Mb SDRAM parts with a 64-bit data bus?
  . You'll need to add more IO buffers for the extra data and address signals (in sdrm.v)
  . You'll need to change ADDR_MSB and DATA_MSB (in define.v)
  . In the current design, instead of 1 tristate signal for the Data lines,
    we duplicate it to 4 signals, each having 8 loads.
    This was done to reduce net delays on that tristate signal.
    You may need to add 4 more tristate lines if you're going to 64-bit.
    The tristate signal is sd_doe_n in sdrm.v
评论(0)
发评论
下载排行榜
