用M68HC11微控制器和WSI的可编程外围设备进行系统开发
消耗积分:0 | 格式:rar | 大小:35 | 2009-06-19
旧念
分享资料个
Following system development using M68HC711 microcontroller (MCU) devices with EPROM or one time programmable ROM (OTPROM), a final design is often implemented using an equivalent mask-programmed M68HC11 device. However, there is a quick, cost-effective alternative to this method of going to production.
WSI manufactures a complete line of PSD programmable MCU peripherals that make it possible to use a ROM-less M68HC11 derivative instead of a mask-programmed device. PSD devices combine EPROM,SRAM, programmable logic for memory map decoding, programmable I/O ports, an address latch, power management, and other capabilities on a single chip. A “twin chip” solution can increase flexibility, provide
expanded memory and enhanced I/O, lower power consumption, and lower cost — all with a minimum of software and hardware modifications.
评论(0)
发评论
下载排行榜
