中兴DWDM的技术规范
消耗积分:5 | 格式:rar | 大小:140 | 2009-06-26
王军
分享资料个
ITU-T G.650 Definition and test methods     for the relevant                                     parameters of single-mode fibers
ITU-T G.652 Characteristics of a single-mode optical fibre cable
ITU-T G.653 Characteristics of a dispersion-shifted single-mode
            optical fibre cable
ITU-T G.655 Characterization of a non-zero dispersion single-mode
            optical fibre cable
ITU-T G.661  Definition and test methods for the relevant generic
             parameters of optical amplifier devices and subsystems
ITU-T G.662  Generic characteristics of optical fibre amplifier
ITU-T G.663  Application related aspects of optical fibre amplifier
ITU-T G.664  General automatic power shut-down procedures for
             optical transport systems
ITU-T G.671  Transmission characteristics of passive optical
             components
ITU-T G.681  Functional characteristics of interoffice and long-haul line
             systems using optical amplifiers, including optical
                                multiplexing
ITU-T G.691  Optical interface for single channel SDH system with
             optical amplifiers, and STM-64 systems
ITU-T G.692  Optical interfaces for multi-channel systems with optical
             amplifiers
ITU-T G.709  Network Node Interface for the optical transport
             network
ITU-T G.825  The control of jitter and wander within digital networks
             which are baser on the synchronous digital hierarchy
             (SDH)
ITU-T G.826   Error performance parameters and objectives for
              international,constant bit rate digital paths at or above
              the primary rate
ITU-T G.958   Digital line systems based on the synchronous digital
              hierarchy for use on optical fibre cables
评论(0)
发评论
下载排行榜
