详述接近/环境光传感器芯片的I2C接口 SI114数据表
消耗积分:0 | 格式:pdf | 大小:453KB | 2014-07-29
lyvinglin
分享资料个
The Si1141/42/43 is a low-power, reflectance-based, infrared proximity and ambient light sensor with I2C digital interface and programmable-event interrupt output。This touchless sensor IC includes an analog-to-digital converter,integrated highsensitivity visible and infrared photodiodes, digital signal processor,and one, two,or three integrated infrared LED drivers with fifteen selectable drive levels。 The Si1141/42/43 offers excellent performance under a wide dynamic range and a variety of light sources including direct sunlight。The Si1141/42/43 can also work under dark glass covers。 The photodiode response and associated digital conversion circuitry provide excellent immunity to artificial light flicker noise and natural light flutter noise。 With two or more LEDs, the Si1142/43 is capable of supporting multiple-axis proximity motion detection。 The Si1141/42/43 devices are provided in a 10-lead 2x2 mm QFN package and are capable of operation from 1.8 to 3.6 V over the –40 to +85 °C temperature range。
评论(0)
发评论
下载排行榜
