6N136单通道,高速光耦合器
消耗积分:1 | 格式:pdf | 大小:691KB | 2014-08-06
分享资料个
These diode-transistor optocouplers use an insulating layer between a LED and an integrated photodetector to provide electrical insulation between input and output。Separate connections for the photodiode bias and output-transistor collector increase the speed up to a hundred times that of a conventional phototransistor coupler by reducing the base-collector capacitance。
评论(0)
发评论
下载排行榜
