全英版详述TPA3112D1
消耗积分:10 | 格式:pdf | 大小:845KB | 2014-08-12
韩利笑笑
分享资料个
The TPA3112D1 is a 25-W efficient, Class-D audio power amplifier for driving a bridge tied speaker。Advanced EMI Suppression Technology enables the use of inexpensive ferrite bead filters at the outputs while meeting EMC requirements。SpeakerGuard™  speaker protection system includes an adjustablepower limiter and a DC detection circuit。 The adjustable power limiter allows the user to set a "virtual" voltage rail lower than the chip supply to limit the amount of current through the speaker。The DC detect circuit measures the frequency and amplitude of the PWM signal and shuts off the output stage if the input capacitors are damaged or shorts exist on the inputs。
评论(0)
发评论
下载排行榜
