【美信】DeepCover嵌入式安全解决方案MAX66242
消耗积分:0 | 格式:pdf | 大小:1572KB | 2014-10-21
孔令双
分享资料个
  The DeepCover Secure Authenticator (MAX66242) is a transponder IC that combines an ISO/IEC 15693 and ISO 18000-3 Mode 1-compatible RF front-end,an I2C front-end,a FIPS 180-based SHA-256 engine and 4096 bits of user EEPROM in a single chip. A bidirectional security model enforces two-way authentication between a host system and the MAX66242. Each device has its own guar-anteed unique 64-bit ROM ID that is factory programmed into the chip. This ROM ID is used as a fundamental input parameter for cryptographic operations and serves as an electronic serial number within the application。
评论(0)
发评论
下载排行榜
