AD9851 CMOS 180 MHz DDS/DAC Synthesizer
消耗积分:0 | 格式:PDF | 大小:271KB | 2015-04-10
lpy137510
分享资料个
The AD9851 is a highly integrated device that uses advanced DDS technology, coupled with an internal high speed, high performance D/A converter, and comparator, to form a digitallyprogrammable frequency synthesizer and clock generator function. When referenced to an accurate clock source, the AD9851 generates a stable frequency and phase-programmable digitized analog output sine wave. This sine wave can be used directly as a frequency source, or internally converted to a square wave for agile-clock generator applications. The AD9851’s innovative high speed DDS core accepts a 32-bit frequency tuning word, which results in an output tuning resolution of approximately 0.04 Hz with a 180 MHz system clock. The AD9851 contains a unique 6× REFCLK Multiplier circuit that eliminates the need for a high speed reference oscillator. The 6× REFCLK Multiplier has minimal impact on SFDR and phase noise characteristics.The AD9851 provides five bits of programmable phase modulation resolution to enable phase shifting of its output in increments of 11.25°.
评论(1)
发评论
rongjinzhuo 2015-07-24
0 回复 举报
好评,,谢谢分享~ 收起回复
下载排行榜
全部1条评论
