具有脉宽调制抑制的高侧驱动,高侧电磁阀显示器_英版
消耗积分:1 | 格式:rar | 大小:104 KB | 2016-11-09
liujie
分享资料个
A solenoid is an electromechanical device that is made up of a coil wound around a movable iron material, also called an armature or plunger. When an electric current is passed through the coil a magnetic field is generated causing the armature to travel over a fixed range.
评论(0)
发评论
下载排行榜
