AD8323,pdf datasheet (Output P
消耗积分:0 | 格式:rar | 大小:556 | 2009-09-03
王利祥
分享资料个
The AD8323 is a low-cost, digitally controlled, variable gain amplifier
optimized for coaxial line driving applications such as cable
modems that are designed to the MCNS-DOCSIS upstream
standard. An 8-bit serial word determines the desired output gain
over a 53.5 dB range resulting in gain changes of 0.7526 dB/LSB.
The AD8323 comprises a digitally controlled variable attenuator
of 0 dB to –53.5 dB, which is preceded by a low noise, fixed
gain buffer and is followed by a low distortion high power amplifier.
The AD8323 accepts a differential or single-ended input
signal. The output is specified for driving a 75 Ω load, such as
coaxial cable.
评论(0)
发评论
下载排行榜
