直流无刷电机驱动与失速电流限制参考设计
消耗积分:1 | 格式:rar | 大小:10.6 MB | 2024-05-13
张瑾
分享资料个
The TIDA-00772 is an 18-ARMS drive for a three-phase brushless DC (BLDC) motor in power tools. The device operates off of a 5-cell Li-Ion battery with a voltage of up to 21 V. The design is a 45-mm × 50-mm compact drive that implements sensor-based trapezoidal control. The design uses a discrete, compact MOSFET-based three-phase inverter that delivers an 18 ARMS continuous (60-A peak for 1 s) winding current without external cooling or heat sink. The slew-rate control and triple charge pump of the gate drive ensures maximum inverter efficiency and optimum EMI performance.
评论(0)
发评论
下载排行榜
