AD9869,pdf datasheet (Broadband Modem)
消耗积分:0 | 格式:rar | 大小:850 | 2009-09-08
郝埃连
分享资料个
The AD9869 is a mixed-signal front-end (MxFE®) IC for transceiver applications requiring Tx path and Rx path functionality with data rates up to 80 MSPS. A lower cost, pin-compatible version of the AD9866, the AD9869 removes the current amplifier (IAMP) IOUTP functionality and limits the PLL VCO operating range of 80 MHz to 200 MHz.
评论(0)
发评论
下载排行榜
