AD1958,pdf datasheet (DAC)
消耗积分:0 | 格式:rar | 大小:549 | 2009-09-12
分享资料个
The AD1958 has a simple but flexible serial data input port that
allows for glueless interconnection to a variety of ADCs, DSP
chips, AES/EBU receivers, and sample rate converters. The
AD1958 can be configured in left-justified, I2S, right-justified,
or DSP serial-port-compatible modes. It can support 16, 20,
and 24 bits in all modes. The AD1958 accepts serial audio data
in MSB first, two’s-complement format, and operates from a
single 5 V power supply. It is fabricated on a single monolithic
integrated circuit and housed in a 28-lead SSOP package for
operation over the temperature range –40°C to +105°C.
评论(0)
发评论
下载排行榜
