ADN2821,pdf datasheet (Transim
消耗积分:0 | 格式:rar | 大小:510 | 2009-09-23
分享资料个
The ADN2821_2/5/10 are a series of compact, high
performance SiGe 3.3V power supply Trans-impedance
Amplifiers (TIAs) optimized for small form factor 10Gbps
Metro-Access and Ethernet PD-TIA modules. The ADN2821
series features low input referred noise current and a range of
trans-impedance gains, suitable for driving a typical CDR or
transceiver directly. 8GHz minimum BW enables up to
11.1Gbps operation; 1.1μA input referred noise current enables
−19dBm sensitivity; 3.25dBm input overload current at a 10dB
extinction ratio. RSSI output signal proportional to average
input current is available for monitoring and alarm generation.
评论(0)
发评论
下载排行榜
