ADN2882,pdf datasheet (Transim
消耗积分:0 | 格式:rar | 大小:517 | 2009-09-23
久醉不醒
分享资料个
The ADN2882 is a 3.3 V high gain SiGe transimpedance amplifier (TIA) which converts the small signal current of a photo detector to a large differential voltage output. The ADN2882 features a typical 475 nA input-referred noise, enabling an optical sensitivity of −22 dBm (0.85 A/W PIN). With a bandwidth of 3.5 GHz, the ADN2882 allows a data rate operation up to 4.25 Gbps. Typical power dissipation is 80 mW.
评论(0)
发评论
下载排行榜
