ADL5531,pdf,datasheet (20 MHz
消耗积分:0 | 格式:rar | 大小:433 | 2009-09-23
分享资料个
20 MHz to 500 MHz IF Gain Blocks:The ADL5531 is a broadband, fixed-gain, linear amplifier that operate at frequencies up to 500 MHz. The device can be used in a wide variety of wired and wireless devices including cellular, GSM and WCDMA, and broadband applications.
Gain is stable over frequency, temperature, power supply and from device to device. The ADL5531 achieves an OIP3 of 41.6 dBm with an output compression point of +20.7 dBm and a noise figure of 2.5 dB.
评论(0)
发评论
下载排行榜
