MPS-MP1470规格书
消耗积分:2 | 格式:pdf | 大小:446KB | 2017-03-08
袁浪
分享资料个
低成本MPS_MP1470规格书
  The MP1470 is a high-frequency, synchronous, rectified, step-down, switch-mode converter with internal power MOSFETs. It offers a very compact solution to achieve a 2A continuous output current over a wide input supply range, with excellent load and line regulation. The MP1470 has synchronous-mode operation for higher efficiency over the output current-load range. Current-mode operation provides fast transient response and eases loop stabilization. Protection features include over-current protection and thermal shutdown. The MP1470 requires a minimal number of readily-available, standard, external components and is available in a space-saving 6-pin TSOT23 package.
评论(0)
发评论
下载排行榜
