基于PCI总线运动控制卡WDM驱动程序设计
消耗积分:0 | 格式:rar | 大小:344 | 2009-10-12
李鸿洋
分享资料个
本文给出了一种使用 DriverStudio 设计WDM 驱动程序的方法,用以实现数控系统
应用程序对运动控制卡的访问。文中以基于PCI 总线的运动控制卡为对象,在构架其硬件结构的基础上,阐述了设计WDM 驱动程序的主要步骤,开发了WDM 驱动程序,在Windows环境下进行测试,达到了预期目的。
关键词:WDM;PCI;DriverStudio
Abstract:A method of designing WDM driver by using DriverStudio is presented in the paper in order that the CNC application can communicate with the motion controlling card. With the motion controlling card based on PCI bus as the object, the paper describes the primary steps to design WDM driver on the basis of structuring the hardware of the card. The WDM driver for the motion controlling card based on PCI bus has been developed and tested in Windows environment,and the prospective target has been achieved.
Keywords:WDM;PCI;DriverStudio
评论(0)
发评论
下载排行榜
