乐袋L1000带DSP2.1功放模块30W+10WX2 ,具备14段音频调解,设计出来的音质超棒。
General Description
The L-1000 is a single chip digital audio amplifier Module. Including power stage for stereo amplifier system. The L-1000 is integrated with versatile digital audio signal processing functions, ADC functions, high-performance, high-fidelity Fully digital PWM modulator and two high-power full-bridge MOSFET Power stages. The L-1000 receives digital serial audio Data with sampling frequency from 8KHZ through 96KHZ. It delivers 2 x 30 watts in stereo mode without heat sink. The L-1000 has a mixer and Bi-Quad filters which can Be used to implement the essential audio signal processing Functions like loudness control, compensation of a loud Speaker response and parametric equalization. All the functions of the L-1000 can be controlled by internal Register values from MCU via I2C host interface bus.
Features
1: 2 CH Stereo (30W x 2@24V 6Ohm) 2: 2.1 channel (10W X 2+30W@24V 6Ohm) 3: Wide Operating Supply Voltage Range (7V to 24V) 4: Floating Point Operation 5: 25 Programmable Bi-Quad Filters Speaker Compensation LPF, HPF Parametric Equalizer Loudness Control 6: 100Db Dynamic Range 7: 2 Band Dynamic Range Control 8: 5 Band Graphic Equalizer 9: 3D Surround 10: Protection Circuit OCP (Over Current Protection) OTP (Over Temperature Protection) UVP (Under Voltage Protection) 11: High Efficiency 12: DC cut filter
