STM32高级定时器-PWM简单学习案例
典型参考设计
3人已加入
  高级定时器与通用定时器比较类似,下面是一个TIM1 的PWM 程序,TIM1是STM32唯一的高级定时器。共有4个通道有死区有互补。
  先是配置IO脚:
  GPIO_InitTypeDef GPIO_InitStructure;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1,ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
  TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  TIM_OCInitTypeDef TIM_OCInitStructure;
  void Tim1_Configuration(void)
  TIM_DeInit(TIM1); //重设为缺省值
  TIM_TimeBaseStructure.TIM_Prescaler = 4000; //预分频(时钟分频)72M/4000=18K
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //向上计数
  TIM_TimeBaseStructure.TIM_Period = 144; //装载值 18k/144=125hz 就是说向上加的144便满了
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //设置了时钟分割 不懂得不管
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 0x0; //周期计数器值 不懂得不管
  TIM_TimeBaseInit(TIM1,&TIM_TimeBaseStructure); //初始化TIMx的时间基数单位
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //PWM模式2
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //正向通道有效 PA8
  TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable; //反向通道也有效 PB13
  TIM_OCInitStructure.TIM_Pulse = 40; //占空时间 144 中有40的时间为高,互补的输出正好相反
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low; //输出极性
  TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low; //互补端的极性
  TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset; //空闲状态下的非工作状态不管
  TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset; //先不管
  TIM_OC1Init(TIM1,&TIM_OCInitStructure); //数初始化外设TIMx通道1这里2.0库为TIM_OCInit
  TIM_Cmd(TIM1,ENABLE);
  TIM_CtrlPWMOutputs(TIM1,ENABLE);
  //设置捕获寄存器1
  void SetT1Pwm1(u16 pulse)
  TIM1-》CCR1=pulse;
  //在MAIN 中加点键盘扫描啥的用来改变占空比
  #include “STM32Lib\\stm32f10x.h”
  #include “hal.h”
  extern void SetT1Pwm1(u16 pulse);
  int main(void)
  u16 pulse=40;
  ChipHalInit(); //片内硬件初始化
  ChipOutHalInit(); //片外硬件初始化
  for(;;)
  if(GET_UP())
  while(GET_UP());
  if(pulse《=144)
  pulse+=5;
  SetT1Pwm1(pulse);
  if(GET_DOWN())
  while(GET_DOWN());
  if(pulse》30)
  pulse-=5;
  SetT1Pwm1(pulse);
  S
  • 相关推荐
  • S
