信号源、调节器和电源电路的应用
消耗积分:0 | 格式:rar | 大小:0.84 MB | 2017-05-03
分享资料个
  Introduction Occasionally, we are tasked with designing circuitry for a specific purpose. The request may have customer origins or it may be an in-house requirement. Alternately, a circuit may be developed because its possibility is simply too attractive to ignore1. Over time, these circuits accumulate, encompassing a wide and useful body of proven capabilities. They also represent substantial effort. These considerations make publication an almost obligatory proposition and, as such, a group of circuits is presented here. This is not the first time we have displayed such wares and, given the encouraging reader response, it will not be the last2. Eighteen circuits are included in this latest effort, roughly arranged in the categories given in this publication’s title. They appear at the next paragraph.
  Voltage Controlled Current Source—Ground Referred Input and Output A voltage controlled current source with ground referred input and output is difficult to achieve. Executions exist, but are often cumbersome, involving numerous components. Figure 1’s conceptual design utilizes a differential amplifier featuring differential, uncommitted feedback inputs. The independent feedback inputs permit the differential signal inputs to operate anywhere inside their common mode range, unencumbered by feedback interaction. Similarly, the differential feedback ports may sense referred to any point within their common mode range. In both cases, common mode range extends from V– to within 2V of the positive rail. Output swing extends to both rails.
信号源、调节器和电源电路的应用
  图1.概念接地电压控制双极电流源采用差分放大器的分离反馈输入。遵守限制是由供应电压,输出电流容量和输入共模范围。
评论(0)
发评论
下载排行榜
