新应用的电子纸显示器之间现在和2022驱动的复合年增长率为13.6%
消耗积分:0 | 格式:rar | 大小:0.33 MB | 2017-05-09
分享资料个
  2016五月的信任研究报告预测,电子纸显示器市场将看到一个年均复合增长率(CAGR)2015和2022之间的13.6%。我们大多数人所熟悉的技术通过其广泛使用在电子阅读器,如亚马逊的Kindle,它在零售店的巨大成功。世界各地的零售商已经节省了数十亿美元,通过更换纸质货架标签与可配置的电子纸版本。这些电子货架标签(ESL)意味着标牌可以自动更新定价或其他信息,包括特别优惠,现在有一个版本显示黑色,红色和白色的种类和添加的影响。然而,它的新应用的多样性,只有对产品设计者的想象力有限,导致在电子纸显示器需求的惊人增长。
  e-paper is a bistable technology, which means that energy is only consumed when the display is changing. Once it has changed, the display consumes no energy and continues to show information, even when disconnected from its power source. By comparison, LCD or OLED displays are far more power-hungry, needing to be refreshed around 30 times per second, even when the information on the display is not changing. What’s more, e-paper is a reflective display that doesn’t need a light source - although front lighting is an option for nighttime viewing. Backlighting is required for LCD displays and accounts for around 40% of their power consumption. So with e-paper we have a very low power, proven display technology that is easy on the eye and has the further advantage of offering wide viewing angles. In fact, e-paper displays look just like ink on paper, which is not so surprising because they contain the same pigments used in conventional ink printing. So, outside of e-readers and shelf labels, where are they being used? Here are just a few examples.
评论(0)
发评论
下载排行榜
