正确的DAC可以简化您的下一个5G或LTE MIMO设计
使用多个输入空间的多样性、多输出(MIMO)的发射和接收天线方案真的起飞IEEE 802.11a(5 GHz的Wi-Fi),但现在它变得越来越重要,LTE和5G无线,设计师需要仔细看看它是如何工作的,以及关键数字模拟转换器(DAC)在实现最佳的设计游戏。
无线通信链路的设计者通常面临的挑战,在满足项目的多目标。首先,他们必须实现最小误码率(BER)。同时,他们必须努力降低功耗,也节省带宽。当然,这些目标有点冲突:提高BER的最简单的方法是提高功率,因为这样做会增加的信号-噪声比(SNR),并且,使用更多的带宽往往是一种方法来改善BER。
At the system level, the goal of improving performance and meeting these goals usually starts with a sophisticated data-encoding scheme that compresses the bit stream and also adds error detection and correction. However, once this data manipulation is completed, the burden of meeting the link goals falls on the transmit-side amplifier and antenna, and the receive-side antenna and front end.
To improve performance, engineers take advantage of one or more of three diversity techniques:
Time diversity: in its simplest terms, this means repeating the message several times, including interleaving it, as shown in Figure 1.
