四位、10MHz、第二阶调制器
消耗积分:0 | 格式:rar | 大小:0.80 MB | 2017-05-18
分享资料个
  GENERAL DESCRIPTION
  The ADS1204 is a four-channel, second-order,CMOS device with four delta-sigma (ΔΣ) modulators,designed for medium- to high-resolution A/D signal conversions from dc to 39kHz (filter response –3dB) if an oversampling ratio (OSR) of 64 is chosen. The output of the converter (OUTX) provides a stream of digital ones and zeros. The time average of this serial output is proportional to the analog input voltage
  The modulator shifts the quantization noise to high frequencies. A low-pass digital filter should be used at the output of the ΔΣ modulator. The filter serves two functions. First, it filters out high-frequency noise.Second, the filter converts the 1-bit data stream at a high sampling rate into a higher-bit data word at a lower rate (decimation)
四位、10MHz、第二阶调制器
评论(0)
发评论
下载排行榜
