多通道采样键准确的电力线路监测
消耗积分:0 | 格式:rar | 大小:0.09 MB | 2017-05-22
分享资料个
  多通道采样键准确的电力线路监测
  准确的电力线监测已成为一个重要的要求,不仅集中在电网本身,而且在其边缘。对于电网并列的能量收集发电系统,甚至终端设备,持续的电能质量特性的分析,有助于确保电网和附加系统的健康。在电力监控系统的心脏,模拟数字转换器(ADC)在测量线电压和电流在一个水平的精度适合每个应用起着关键性的作用。工程师可以满足一系列的要求从实用级系统的精度需要收入的目的基本电力监控线路故障,利用高性能ADC检测和相关部件制造商包括模拟设备,科宝电子,Intersil,线性技术,集成,芯片技术,半导体,脉冲电子、德克萨斯文书。
  在最基本的层面上,电力监控系统依赖于测量瞬时电压和电流用电流互感器(CTS)和电压互感器(称为PT,电压互感器)输出转换的高速ADCs(图1)。反过来,处理器使用的瞬时电流和电压测量计算的关键特性,包括有功功率,无功功率,视在功率和功率因数,甚至更复杂的计算,如谐波,这可能会导致设备损坏。
  多通道采样键准确的电力线路监测
  Figure 1: A typical power-monitoring system samples line current and voltage, using high-speed analog-digital converters (ADCs) to provide high-resolution data to the host processor for calculation of power parameters. (Courtesy of Texas Instruments)
  Performing these power calculations depends foremost on accurately measured voltage and current. Standards such as ANSI C12.20 for North America and IEC 62053 dictate specific accuracy levels such as Class 0.2, which requires ± 0.2 percent accuracy. In practice, power-measurement systems are typically designed to surpass standard accuracy specifications—relying on high-sample rates and high-resolution converters to capture high-speed transients and to ensure reliable calculation of more complex characteristics such as multiple harmonics.
评论(0)
发评论
下载排行榜
