Nios II Hardware Development
消耗积分:3 | 格式:pdf | 大小:1515KB | 2017-05-23
qsx123456789
分享资料个
阿阿斯顿ADSasdASDasdASD1
This tutorial introduces you to the system development flow for the Nios® II processor. Using the Quartus® II software and the Nios II Embedded Design Suite (EDS), you build a Nios II hardware system design and create a software program that runs on the Nios II system and interfaces with components on Altera® development boards. The tutorial is a good starting point if you are new to the Nios II processor or the general concept of building embedded systems in FPGAs. Building embedded systems in FPGAs involves system requirements analysis, hardware design tasks, and software design tasks. This tutorial guides you through the basics of each topic, with special focus on the hardware design steps. Where appropriate, the tutorial refers you to further documentation for greater detail. f If you are interested only in software development for the Nios II processor, refer to the tutorial in the Getting Started with the Graphical User Interface chapter of the Nios II Software Developer’s Handbook. When you complete this tutorial, you will understand the Nios II system development flow, and you will be able to create your own custom Nios II system.
评论(0)
发评论
下载排行榜
