应用程序特定的MCU瞄准新兴应用
他们是自然的模式,microcontrollers通用,通用设备,可以在宽范围内控制to address of任务。他们有高度进化tracked for the capable低成本需求,但他们现在powerful devices such as enable和在宽范围的前端产品。predominantly of their平衡成本,性能和灵活性,relatively is chosen for a range of applications特异性allowing制造商提供解决方案,在最优投资组合在of variants)。飞思卡尔,for example of different,offers安基超900 ARM MCU继续增加likely to,with the人物介绍ARM Cortex - M7 of the核。
虽然一个家庭中的每一个范围通常是优化的,但往往是交叉的应用程序,他们的地址,让最终客户选择最适合他们的特定要求的设备。然而,有时应用程序有这样的特定要求,设备制造商愿意和能够开发设备,功能专用于该应用程序的外围设备。虽然不是通用的,严格来说,他们往往是基于标准的MCU内核和外围设备,这使得它们适合于特定的应用程序,同时保持一定程度的灵活性。
Integrated audio
Advances and maturity in process nodes means it’s increasingly viable to integrate optimized functionality alongside general-purpose peripherals, particularly when targeting high volume applications. One example is audio; a feature that is increasingly common in many devices. To address this market, Nuvoton Technology Corporation developed the ISD9160, a single-chip solution for audio record and playback.
