使用MEMS加速度计进行工业物联网比以往任何时候都容易
消耗积分:0 | 格式:rar | 大小:0.56 MB | 2017-06-22
分享资料个
  在工业应用中,经常需要测量与运动有关的量,如压力、速度和加速度。然而,可以测量这些参数的传感器的部署受到成本的阻碍,以及由于不可预见的机械和电子因素难以获得精确和一致的测量。
  这是不幸的,因为这些参数的实际值以及这些值的相对变化,可以提供基本系统操作、影响检测、即将发生的故障、过度振动和未经授权的移动的洞察力。因此,重要的是,设计师考虑第二次看看他们的传感选项。
  确实,有些解决方案只能在有限的、专门的应用程序中可行,因为成本和复杂性是次要的。然而,随着低成本、低功耗、基于MEMS的运动和加速度传感集成电路的发展,这种情况发生了巨大的变化。
  This article will briefly describe some Industrial Internet of Things (IIoT)) application scenarios where designs benefit from data on motion related parameters. It will also explain the not-so-obvious difficulties of obtaining accurate and consistent measurements with these devices, which is due to both electronic and mechanical issues.
  Following a brief review of the underlying physics principles, it will look at relevant products, their specifications, and application areas. It will then raise critical issues regarding mechanical placement and mounting, and look at reference designs/evaluation boards that can help developers quickly realize the end application.
评论(0)
发评论
下载排行榜
