LED照明的智能控制,使能源效率更高
消耗积分:0 | 格式:rar | 大小:0.12 MB | 2017-06-23
分享资料个
  LED照明的智能控制,使能源效率更高
  本文认识到,采用LED照明是迈向绿色经济的重要一步,通过更换传统白炽灯,甚至更节能的荧光灯管和紧凑型荧光灯,可以节省大量能源。它扩大了这一主题,认为更有效的照明光源只是解决方案的一部分。负责任地使用我们宝贵的能源资源要求我们采用智能控制,以确保我们家、办公室、工厂和街道上的照明只有在需要时和适合这些要求的水平时才打开。本文旨在表明,这些控制是有效的,他们需要平衡方便性和易用性与自动化水平,可以响应运动或房间占用,适应环境光水平,并最终防止能源浪费。
  本文将重点介绍一些LED照明,传感器和控制产品可从Digi-Key包括标准LED灯像罗姆的r-b15l1和r-fac40bn1,从Zilog PIR运动和自动照明传感器(zepir0aas02modg),欧司朗(SFH 5711-2 / 3-z),和Intersil(isl29029iroz-t7),驱动控制器件如二极管“zxld1374est20tc和ATMEL公司的at90pwm316-16mur。
  What is the attraction of LED lighting?
  The headline benefit of using LEDs to light our homes, offices, factories and streets is undoubtedly the energy savings achieved from replacing incandescent bulbs, fluorescent tubes, and most other kinds of lighting technology. Incandescent (tungsten filament) bulbs are notoriously inefficient, with as much as 90% of the input power converted to heat rather than light. Fluorescent lights, either the tubes predominantly used in commercial premises or the compact fluorescent lamps (CFLs) we have been encouraged to use in our homes over the past decade or so, are more efficient, but LEDs can save between 30 to 50% of the energy used by fluorescent lights.
评论(0)
发评论
下载排行榜
