NTC热敏电阻的LED照明系统过热保护
消耗积分:0 | 格式:rar | 大小:0.18 MB | 2017-06-29
分享资料个
  NTC热敏电阻的LED照明系统过热保护
  高亮度、大功率LED(HBLED),像任何其他半导体器件产生的热量。因为它是众所周知的,高温会缩短一个HBLED的寿命以及影响亮度、温度控制要求。然而,为了控制温度,设计师首先需要确定如何监测LED模具的温度,这正是负温度系数(NTC)热敏电阻在LED照明系统中的作用。
  不同的温度传感装置,包括二极管,内置传感器,正温度系数(PTC)热敏电阻,和电阻温度检测器(RTD),可用于LED照明应用的高亮度LED过热保护。然而,NTC热敏电阻是温度的检测和控制在这些应用中的首选,主要是因为他们的小封装尺寸和极具吸引力的价格/性能比。
  NTC热敏电阻的LED照明系统过热保护
  Comparing NTC thermistors to different temperature sensing solutions, Bruno Van Beneden, senior manager application support and design-in for Vishay Non-Linear Resistors, noted that diodes have low accuracy and limited temperature range; on-chip sensors have higher cost and limited temperature range; PTC thermistors have limited accuracy in a very limited temperature range, and RTDs are often too costly, with the possible exception of Ni thin-film RTDs.
  The NTC thermistor‘s sensitivity to temperature changes, even in small increments, enables the device to be used in temperature sensing/control applications. These devices allow the LEDs to withstand higher current over temperature (via compensation) to enhance the LED’s lifetime. The current can be controlled according to ambient temperature by the NTC thermistor as shown in Fig. 1.
评论(0)
发评论
下载排行榜
