用集成传感器同时检测多个参数
消耗积分:0 | 格式:rar | 大小:0.14 MB | 2017-07-03
分享资料个
  用集成传感器同时检测多个参数
  位于手指尖端的传感器不仅是接触感受器,还包括压力传感器、形状传感器、温度传感器和液体粘度传感器。它们同时将机械和热信息转换成发送给大脑的电信号,通过模式识别程序提供反馈信息。随着性能的提高和多传感器集成在一个单一的传感器模块,结合他们的输出的有效性,设计师创建系统,在一个规模较小但不像我们的手指和大脑,可以使高层推论各种环境条件下的。在这篇文章中,我们将研究新的集成多功能传感器模块和智能传感器应用这些设备使之成为可能。
  智能导航系统
  首先,考虑电子导航系统。我们很快就习惯于拥有便携式电子产品,根据需要,它可以告诉我们我们在哪里。当汽车旅行到一个新的或陌生的地方,大多数司机现在将依靠GPS导航系统或手机应用程序,以获得他们想要去的地方。
  用集成传感器同时检测多个参数
  These systems work well, but those of us who have used them often know there’s room for improvement. There are times when the navigation system seems to get confused about which level of a tiered highway we are on, or the system loses location when it is unable to obtain a GPS signal for any length of time, for instance, when traveling through a tunnel.
  It is possible to overcome these problems by using the inputs from several sensors simultaneously to obtain accurate position information without an external signal. Rather than rely on a single type of sensor, say an accelerometer, inputs from multiple sensors or from a single, multifunctional sensor module can be combined algorithmically to produce reliable position data.
评论(0)
发评论
下载排行榜
