14位ADC接口到飞思卡尔i.mx257 HMI应用
问题:我如何获得更高的分辨率,高速ADC(模拟数字转换器)接枝在飞思卡尔i.MX处理器的HMI(人机界面)应用程序吗?
根据飞思卡尔半导体数据表,处理器i.MX系列包括“低功耗,对于一般的嵌入式工业和消费市场,优化高性能的设备。与主机的集成外设,该设备是一种应用广泛的用途,包括人机界面(HMI)面板,工业驱动器,PLC,I/O显示,工厂机器人显示和图形化的远程控制,手持扫描仪和打印机,病人监护仪,便携式医疗设备,智能电表,能源网关媒体手机媒体网关。”
仔细考虑整个系列的家庭后,我们根据我们的设计的i.mx257(Digi-Key部分# mcix257djm4a-nd),一个多路器,集成的12位ADC。虽然有一个集成的ADC是方便,我们的客户应用的要求:至少有14位分辨率两个模拟通道,和一个额外的设计条件,即“达到最快的采样率,可以送入处理器的显示,在合理的成本约束。”七英寸触摸显示屏分辨率为800 x 480(WVGA),一个好的像素数必须填写。
Further complicating our design, all available GPIO ports were in use, which precluded the use of a parallel interfaced ADC.
The options left open to us were either to use an ADC that interfaced serially (SPI or I2C), or develop a separate subsystem to DMA the ADC’s data into shared memory. Since the i.MX chips all have an internal dynamic memory controller, trying to shoehorn a dual ported memory structure supporting external DMA commands into the existing integrated memory controller started to look way too complicated and expensive to implement, and after some serious conceptual study, we decided to find a simpler, more elegant solution.
