Wi-Fi模块提供完整的信号链解决方案
消耗积分:0 | 格式:rar | 大小:0.08 MB | 2017-07-14
分享资料个
  Wi-Fi模块提供完整的信号链解决方案
  IEEE 802.11标准在标准TCP/IP协议栈的最低级别定义了媒体访问控制(MAC)和物理层中的通信协议。而MAC层管理通信与其他站,PHY层提供无线通信服务,利用各种扩频信号的载波调制技术传输数据包可靠尽管用于无线通信的带宽从其他流行的无牌无线电发射机的干扰。
  802.11标准还定义了各种PHY的扩频技术,包括跳频扩频(FHSS),直接序列扩频(DSSS)、正交频分复用(OFDM)。FHSS开关在不同频率的载波,而扩频传播信号在更大的频谱比原始信号的带宽。ofdm同时在多个频带上并行传输数据,以低码元速率提供高吞吐量。在这些扩频方案中,Wi-Fi系统利用了基于正交幅度调制(QAM)和相移键控(PSK)的各种编码技术。这些技术通常需要复杂的调制和解调方法,将额外的复杂性引入信号链中。
  In designing a basic Wi-Fi system, engineers face a complex signal chain starting with an RF front end capable of filtering and amplifying the RF signal as well as performing the RF-to-intermediate-frequency (IF) conversion needed to generate in-phase (I) and quadrature (Q) signals. Using analog-to-digital converters (ADC), the next stage of the Wi-Fi signal chain relies on a PHY baseband processor to perform carrier sensing and handle frame transmission or reception. Within this stage, quadrature demodulators comprising well-matched mixers, phase shifters, and low-pass filters convert the IF signal to baseband I and Q signal components for further downstream processing. For transmission, quadrature modulators provide this function in reverse. Finally, the MAC controller transfers the data to and from downstream application circuitry and host systems.
评论(0)
发评论
下载排行榜
