CS4392_PP3英文资料
消耗积分:0 | 格式:pdf | 大小:1190KB | 2017-07-28
夏天198400
分享资料个
CS4392DAC
  Description
  The CS4392 is a complete stereo digital-to-analog sys-tem including digital interpolation, fifth-order delta-sigmadigital-to-analog conversion, digital de-emphasis, vol-ume control, channel mixing and analog filtering. Theadvantages of this architecture include: ideal differentiallinearity, no distortion mechanisms due to resistormatching errors, no linearity drift over time and tempera-ture, and a high tolerance to clock jitter.
  The CS4392 accepts PCM data at sample rates from4kHz to 192kHz, DSD audio data, has selectable digitalfilters, and consumes very little power. These featuresare ideal for DVD, SACD players, A/V receivers, CD andset-top box systems. The CS4392 is pin and registercompatible with the CS4391, making easy performanceupgrades possible
CS4392_PP3英文资料
评论(0)
发评论
下载排行榜
