TOP258PN英文资料下载
消耗积分:5 | 格式:pdf | 大小:3732KB | 2017-08-07
罗剑
分享资料个
TOP258PN
  Lower System Cost, Higher Design Flexibility • Multi-mode operation maximizes efficiency at all loads • New eSIP-7F and eSIP-7C packages • Low thermal impedance junction-to-case (2 °C per watt) • Low height is ideal for adapters where space is limited • Simple mounting using a clip to aid low cost manufacturing • Horizontal eSIP-7F package ideal for ultra low height adapter and monitor applications • Extended package creepage distance from DRAIN pin to adjacent pin and to heat sink • No heat sink required up to 35 W using P, G and M packages with universal input voltage and up to 48 W at 230 VAC • Output overvoltage protection (OVP) is user programmable for latching/non-latching shutdown with fast AC reset • Allows both primary and secondary sensing • Line undervoltage (UV) detection prevents turn-off glitches • Line overvoltage (OV) shutdown extends line surge limit • Accurate programmable current limit • Optimized line feed-forward for line ripple rejection • 132 kHz frequency (254Y-258Y and all E/L packages) reduces transformer and power supply size • Half frequency option for video applications • Frequency jittering reduces EMI filter cost
TOP258PN英文资料下载
评论(0)
发评论
下载排行榜
